Finishing Auto to T5 Swap
Old Sep 8, 2005 | 01:02 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Hey all, I'm pretty much done with my tranny swap, got the floor cut for the shifter, and the hole cut for the pedal assembley, everythings just about done, but one simple thing I am just not 100% sure on is what kind of fluid to put in the tranny and where to put it and how much, I've read that I can put either ATF or Gear Oil, but I'd like to be sure before I start pouring stuff in Any help would be appreciated.
Old Sep 8, 2005 | 03:05 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
hey im also doing the swap, was it hard to cut the floor and firewall ? any help and advice would be very helpful i have to pull the 700r-4 and mount everything up still, seems to me that pulling the auto is about the same as pulling the manual, same steps....... sorry to hijack your thread
Old Sep 8, 2005 | 09:53 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
On the passenger side of the T5, you will see two threaded plugs, one closer to the top of the tranny, and one near the bottom. I think they might even be 3/8th drive sockets, but don't quote me, I haven't looked at my T5 since last summer. You can drain out from the lower plug, and refill through the upper plug. Use good ATF, since that's what GM used from the factory.
Old Sep 8, 2005 | 11:51 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
acttualy it was really easy, just gotta take measurments and cut, the floor was a breeze, i used a dremel tool with cutting bits. the firewall was also easy until i broke my last cutting bit, so i ended up using a hacksaw blade. So it took a little more time then i wanted but it still came out clean. very straight forward project and easy to be honest
one thing i would recomend is dont use those brittle cutting bits, you'll go through too many of those, use the thick fiber looking ones.
Car: 1986 Trans Am
Engine: 5.7L TPI
thank you very much,
rubblerubble
Mar 13, 2016 06:57 PM
slowsi
Oct 18, 2015 08:49 PM
91 SrS
Oct 7, 2015 04:32 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
88rscamar0
Sep 23, 2015 09:08 PM
