Please LOOK
Old Sep 15, 2005 | 08:40 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
Please LOOK
OK so here is my question. I have my old 700R4 that worked great before my motor install. When I installed the trans back in with the new motor I didn't get the torque convertor on all the way. When I started the motor and tried to move the car nothing happened. I suspected that I just burnt up the front pump. Could that be all thats wrong with it or do you guys think that it's more in depth?? Please let me know your opinions. Thanks
Old Sep 15, 2005 | 09:36 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Did you lose fluid? Any leaks?
Old Sep 16, 2005 | 01:16 PM
Engine: carbed 383
Trans didn't lose any fluid, leak, or anything of that sort.
Old Sep 16, 2005 | 05:41 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If the torque converter was not fully seated you likely broke the pump. Prepare for a big bill to fix it.
Old Sep 16, 2005 | 08:22 PM
Engine: carbed 383
But is it just the pump thats bad you think? I have a pump for it.
Old Sep 16, 2005 | 09:12 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
If you are lucky, you only broke the pump. If the trans ran with no pump pushing fluid, you may have smoked it as well. If you have a spare pump, swap it out and hope for the best.
