t56 and manuel linkage??????????
Old Sep 26, 2005 | 08:22 PM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
Transmission: 4 speed manual
is there any way I can use my manuel linkage with a t56 THANKS
Old Sep 27, 2005 | 01:02 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
A T56, like a T5, is internally rail shifted -- no "linkage" that you have to worry about.
Old Sep 27, 2005 | 06:20 AM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
Sorry i meant clutch linkage
Old Sep 27, 2005 | 12:47 PM
Car: 2000 BMW M5
I used the flywheel and clutch pressure plate/disc from my old 4 speed when I upgraded to the T5. However, doesn't the factory T56 use a pull style clutch instead of a push style clutch? That might get dicey.
Old Sep 27, 2005 | 08:36 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
no.
why do you want to?
Old Sep 27, 2005 | 09:18 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, with the retrofit t56 that used the t-5 bellhousing
or you can track down the custom bellhousing and see if the maker can build you one for the manual linkage clutch
Old Sep 28, 2005 | 12:08 AM
crazycrocket's Avatar
Car: 1985 camaro
If Im not mistaken tremec was at one time selling and adapter plate that intalled a t-56 to a 3rd gen bellhousing for the t-5. I hope this helps
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
