manual transmission problems
Old Sep 29, 2005 | 04:25 PM
TooTall90's Avatar
Car: 90 black camaro
Engine: 350 but was a 305
Transmission: manual
i have a 90 camaro that i just replaced the 305 with a 350. i wanted to have a new transmission in it. so i asked a friend if he could get me one well he did and he and the guy he got it from said it would work. well the old one was a borg warner t-5 and the new one is a world class borg warner t-5 that came out of a mustang. at this point and time the transmission will not go into gear when the engine is running but will when it is not. if you try to start it when in gear the car likes to creep forward. all suggestion and ideas are welcome please and if any one knows that this really should work
Old Oct 1, 2005 | 10:12 PM
trakcar's Avatar
Sounds like your clutch is not disengaging. try bleeding the clutch master cylinder.
Old Oct 1, 2005 | 10:27 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Definately sounds like a clutch issue.
Forget to put the release bearing in?
Old Oct 2, 2005 | 09:12 PM
TooTall90's Avatar
i have bleed the slave cylinder. the release bearing is in
Old Oct 2, 2005 | 09:23 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Something got goofed in the install, i would split the trans from the engine and check the pressure plate for damage.
Old Oct 3, 2005 | 07:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
How did you get one from a Mustang in there?
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Jun 22, 2021 08:21 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
