i need help, 700r4 selection
Old Oct 2, 2005 | 12:10 PM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
in spite of the recent death of my 700r4 in my 87 iroc z28, i am looking for a new one
i was looking at bowtie overdrives level 2 and have a few questions, would this bolt directly into my 87, or is ther any differences?
and if anyone has any other suggestions, feel free to let me know
Old Oct 2, 2005 | 12:53 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
yes, it will bolt in. you may have to use your original extension housing and speedo gears, but nothing too serious. everything should be direct replacement.
do you have a pic of your ram air intake? i was curious and looking for ideas.
Old Oct 2, 2005 | 01:14 PM
I-rocin's Avatar
Car: 87 iroc-z28
what do you mean by extension housing?, will there be any parts that i will have to buy to do this, or will it be just transferring parts over
its the same ram air intake that can be seen here
https://www.thirdgen.org/newdesign/tech/ramair.shtml
Old Oct 2, 2005 | 02:44 PM
87zjeff's Avatar
ok. thanks. what did you use for the ducting? i couldn't find any flexible ducting that was 8".
everything should change over from your existing transmission. the tail housing is what the torque arm mounts to. the speedo gears will be so you can keep your speedometer accurate. four bolts hold on the tail housing.speedo gear housing is in the tail housing so that is simple there. the one on the output shaft of the transmission will be the more difficult. it has a slip that you hold down while tapping the drive speedo gear off. teh driven speedo gear is in the speedo housing mounted in the tail housing.
Old Oct 2, 2005 | 03:14 PM
I-rocin's Avatar
Car: 87 iroc-z28
mine are plastic pvc bends, i'm not sure if they're 8 inches, use some large pvc bends, and connect it to some dryer duct, run the dryer duct up as close to teh air box as you can, thats how mine is
thanks for the help
Old Oct 2, 2005 | 10:55 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I currently have a Bowtie Overdrive's level 2 tranny in my car now, it's been in there for over two years, hasn't given me much trouble. It rips thru the gears easily. I can break the tires loose in second gear with no problem.
Old Oct 3, 2005 | 03:38 PM
I-rocin's Avatar
Car: 87 iroc-z28
how much power are you maiking out of your 355?
on the other hand, has anyone heard about or been using a tranny from advance auto, i can get one made to handle 475 hp/500 torque with a shift kit and everything. i was wondering if anyone knows how good these are
Old Oct 3, 2005 | 10:20 PM
Car: 89 Formula
Engine: 383 SBC/HSR
I say about 380 hp out of the crank, but that's just a guess. It's run a best of 12.89 in the 1/4.
I had the guys at Bowtie Overdrive send me two pistons to put in the 1-2 accumulator (instead of the springs) to make the 1-2 shift even firmer and it made a world of difference.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
