Considerng 4L60 to T56 swap, what do I need?
Well, my 2nd gear is completely gone now, and besides I'm tired of autos. I think its time to go with a T56 but parts do I need to work with my 92 with a 350 TPI?
Pedals from a 4th gen will work right? What about from a 3rd gen?
A clutch/flywheel that will work with the newer 1 piece rear main.
Aftermarket or fabbed crossmember.
Cut hole for shifter.
What would I need to make the electric speedo work?
I think I read that the driveshafts are the same length, are they?
Wire up reverse lights.
What is the difference in T56's from LT1s and LS1s?
Is there anthing else? Any guidance would help me here.
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
well i bought a 87 bird that swapped a th700 out for a t-5 basicly to get the speedo to work u need to have the right eletronic sender in there, if not u grab one of the same transmission in the yards, then just connect the wire and go lol
reverse light it fairly easy as far as i can see u just splice the wire for it from the trans to the old auto cable, not sure thou because i didnt do the swap
trying to throw in what i know, hope this helps
1992 Trans Am
Aug 8, 2015 08:16 PM
4l60, camaro, conversion, crossmember, kit, light, needed, reverse, swap, t56, transmission, wiring, work
