Need some suggestions for my diff
Old Oct 9, 2005 | 05:24 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well as i am planning on building up a 383 and possibly a blower ontop of it i know my stock diff isnt going to handle to power. So i was wondering what would be the best way to do this?
The car is a daily driver, will see the track maybe once or twice a year. It is going to be behind an auto tranny so it will have a bit of a cushon between all that power. So its just a car to go back and forth to work with a bit of tearing up the streets on friday night.
What would be my best option, i dont want to build a bulletproof $5000 rearend. Just something that will get me around without blowing up if some dude gets cocky in a civic beside me.
Spool/locker/limited slip/posi?
The 82-90s are 26 spline axles right?
Old Oct 10, 2005 | 01:23 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
i guess ill just blow apart my lil old 10 bolt then...
Old Oct 13, 2005 | 02:16 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You definatly dont want a spool in a street car. Your 10 bolt probably wont last behind a blown 383 unless your having traction issues. You might want to look into a 9 inch or 12 bolt rearend. Itll cost way less than $5000.
These essentally are the same thing. They put traction to both rear wheels instead of just one. The differential type is really just personal preferance and budget.
Old Oct 13, 2005 | 04:44 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
Blown 383.............Detroit Locker......they are almost indestructable............I said almost .........9" or 12 bolt is probably as good as the other. And as many splines on the axles as possible.
gord327
Oct 3, 2015 01:25 PM
Vincent135
Sep 28, 2015 10:50 PM
