stock 700
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
stock 700
got an 84 z28. i have no torque in first gear and the tranny doesnt shift out until almost 6000 when floored. is this normal? i have absolutly no power in first.
Car: Pair of 92 Z28s
Re: stock 700
No 6000rpm for it to shift is not normal lol.
Check you TV cable adjustment...there are post ups on adjusting it everywere search around.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If the car is in gear, and the engine revs, and the car does not move (or barely moves) it sounds like it is time for a new trans. Unless I misunderstand your description. Smell the fluid. If burnt, put a fork in it.
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I would go back to basics. Vacuum check the engine, tune up, check air cleaner, fuel filter for blockage etc. The transmisiions job is to couple the engine to the trans(converter) yhen manipulate gears into the needed ratios in power or reduction. If you are hitting all gears without clutches slipping, you likely have an engine or chassis problem. Go back to the basics and check. Brake caliper hanging up etc.Good luck.
Genopsyde
Oct 7, 2015 08:35 PM
Mickeyruder
Sep 2, 2015 02:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
