From 2.77 to 3.41
Old Oct 25, 2005 | 09:12 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Axle/Gears: 3.42 posi
From 2.77 to 3.41
Can I pull the whole carrier out of a rear with 7.5" 3.41 gears and drop them in my 7.5" 2.77 rear assuming the axle spline count is the same?
Old Oct 25, 2005 | 09:42 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Yes, swap the carrier, ring, and pinion all together.
Old Oct 27, 2005 | 09:20 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
2.77 is a 7.75' BW gear axle ratio (9 bolt)
3.416(3.42) is 7.5/7.625" saginaw gear axle ratio (10 bolt)
are you sure you have 2.77's in your rear? and not 2.73's?
if you currently have a DO have a 10 bolt what is stated above is correct. the two rear ends' parts cannot interchange.
Old Oct 30, 2005 | 09:58 AM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Your right I had 2.73 and now I have 3.42. I was going to just swap the gears but the pinion gear had fused to the inner race so it would not come out. Good news is that since I needed a different rear end I found a 3.42 posi rear for $150. Everything is swaped now, hopefully I can get my new cam and stall in by Thursday so I can post up some lower track times.
ChevyLuva3
Dec 5, 2001 08:50 AM
KeithO
Oct 1, 2001 12:47 PM
89IROC5.7
Aug 31, 2001 12:14 PM
89 Iroc Z
Aug 29, 2001 11:27 AM
JeffD89Iroc
Oct 13, 2000 07:49 AM
