700R4 to Th350 Which torque arm option????
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Im am building a th350 to go into my camaro. It is a long tailshaft, so the driveshaft and crossmember should be fine.
My question is which option should I choose for the torque arm mount?
#1 B&M bracket
#2 Jegster bracket with Torque arm
Or #3 Spohn torque arm and crossmember
I would like to pic #3, but it is really out of my budget.
What do you guys suggest? Any drawback to the other options?
And I have already searched about the 700r4 to th350 tailshaft swap, but I dont want to go that route.
thanks for any advice or experinces you have had with these pieces.
#1 B&M bracket
Car: Camaro
Engine: Carbed L98
Transmission: TH350
What about and #4 Lakewood track action bars
I have seen these and there are a few post about them. If they were welded to the rear end housing, could the torque arm be removed. Probably not a good idea, but I thought I would throw that option out there.
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
does the B&M kit provide absolutely everything you will need for the swap? if so i would go with that.
and a question of my own...will the stock shifter work?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i used the B&M kit and that's the way to go honestly. much better than the hurst kit
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I will probably end up going with the B&M kit. I can always change the Torque arm later. I just want to get the trans in and get everything working good.
I guess I could weld some braces on the original torque arm. I am running the stock 16 year old bushing. Id say its time for a new one. Might be were some of my wheel hop is comming from. Not to mention factory springs and shocks. lol.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'm happy with my B&M kit except it was nearly impossible for me to find the proper clamshell for the TA mount that the kit requires (GM no longer makes the part...) I had to buy the similar one (its in the instructions) and then had to take the bushing off my old one and cut it on the back/bottom to fit.
https://www.thirdgen.org/techbb2/sho...hreadid=258446
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Car: 1984 Z28
my torque arm bushing and clamshell bolted right up from a 1985 torque arm mount. I know there was 3 different styles of torque arm mounting brackets, must have been fun locating the right one.
Car: 1990 camaro RS
Engine: 383 stroker
Transmission: turbo 350
hi buddy
i would think twice about a th350 if you want to go that route look in the th400 its alot tougher than the 350 even with all the build ups for it i have a 383 pushing about 550hp and it tore up my th350 i have a 700r4 after $600 dollars worth of upgrades im hoping will live up to this thing if it doesnt than i have a 4speed t-22 rock crusher that im going to put in it if i can ever figure out how to put pictures on here id show you pieces of 3rd gear sitting in my pan hey who knows it just could have been weak but why take the chance just something to think about
Car: '89 IROC-Z
my TH350 has a stock rebuild on it and has been running strong for over a year now...
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Dana from Probuilt is going to hook me up with one of his transgo kits. Im going with the Red eagle alto clutches, kevlar band, and kolene steels. Its rated for 550hp or better.
Right now if just have too much space between 1st and 2nd with the 700r4. Im also having 2-3 shift flare up at wot. The trans works fine with regular driving. It will also shave a little weight off and be cheaper to build. Besides, not to many th400's floating around in my area.
Thanks for the advice.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the B&M TQ arm mount brackets kit for the th350
was 80 bucks brand new from summit when i bought
works 100% great! no problem whatsoever
only need one of the brackets they send in the kit- for the 200C to th350 swap anyways-
but the swap from 700r4 needs both the B&M brackets,
i have this th350 deal in my 82 trans am,
it was a thm200 originally
works awesome
very good deal
works awesome
very good deal
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
