Installing a Transmission Mount
Old Nov 13, 2005 | 02:47 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
my tranny stays in first gear to long to to a torn mount. My question is, how do i replace it. i got the tranny mount already. i looked under the car but i dont see the part. Is there any advce to make this project go easier. please help thx
Old Nov 13, 2005 | 03:10 PM
ede's Avatar
ede
it's under the tail housing and above the cross member, bolted to each
Old Nov 13, 2005 | 09:12 PM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
in the middle of the crossmember, should have three bolts on it (two on outside and one in the middle)
Old Nov 14, 2005 | 12:13 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
They are pretty simple to replace, i reccomend air tools, the crossmember bolts are usually pretty tight and rusted and if your not carefull they can break. But just place a jack under the tranny, remove the crossmember, remove the bolts holding the shredded mount, put new mount in reinstall crossmember. Its a pretty easy job maybe takes an hour all together.
Old Nov 15, 2005 | 12:36 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I've never done one up untill it broke on me. So it took me about 10mins. to replace. Just pick up a new tranny mount and jack up your tranny. The mount, since its broken, will separate and your tranny will jack up easy. Than I used 17mm socket to get the nuts off the bolts. Yours might be different. Than there might be some fitment issues due to the mount not aligning totally. So, just use a crowbar and move the tranny a bit to where it aligns. That would probably be the biggest part of changing a mount.
Good luck.
Old Nov 15, 2005 | 12:39 PM
The esiest way to tell a tranny mount is comparing the new one you bought to the bottom back end of the tranny. You will see where it is, very easy. If not just do a quick search ( I know) that what helped me find it.
Old Nov 16, 2005 | 12:47 PM
Engine: V8 350 ci
thx guys, i lost my manual so i will be doing this by what you guys told me, im gonna give it a go today, ill let you know how it went. thx for the help.
Old Nov 17, 2005 | 12:07 PM
Hope this helps trannie mount
Old Nov 18, 2005 | 09:49 AM
Engine: V8 350 ci
changed teh new mount but didnt help my problem....the mount was broken but the tranny still stays in first gear too long...probly due to a stripped tranny gear...o well....
Old Nov 18, 2005 | 10:32 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
tv cable may be out of adjustment
Old Nov 19, 2005 | 03:40 PM
Engine: V8 350 ci
TV CABLE ON A CAR?
Old Nov 19, 2005 | 04:53 PM
kevinc's Avatar
Car: 1982 Z28
This is like driving past a really messy car wreck...I just can't help myself from looking.
Old Nov 20, 2005 | 11:29 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Originally posted by tigercyberslash
TV CABLE ON A CAR?
Ok, well the tv cable connects the throttlebody to the transmission it changes the shift points by allowing more tranny fluid to pass through a valve. But i guess i have no idea what im talking about so i wont try to give advice anymore.
Old Nov 20, 2005 | 11:57 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Don't BS on the TV cable thing. 700R4's use these...
Do a few searches around and you'll find a lot about the TV cable & adjusting it, but be very careful because if you adjust it incorrectly you can damage or destroy the transmission. If this is an older transmission, it could also be the valve body spring. If this is the case, adjusting the TV cable may appear to fix the problem, but could actually make things worse. I'd get a replacement spring and/or valve body before going any further.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Wesly_66
Aug 26, 2015 09:55 PM
