t56 flywheel question. need help asap!
Old Nov 15, 2005 | 08:25 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I'm swapping the 4l60 on my zz4 for a t56 out of a 95 t/a.
About the flywheel. Can I use the one directly off the LT1? I got a flywheel with the tranny and I had bought one off ebay that claimed to be neutrally balenced for use in internally balanced engines which I thought is what the zz4 was.
Does anyone know? should I just use the stock LT1 flywheel?
Old Nov 15, 2005 | 10:27 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
the zz4 is a one piece rear main seal motor right? if so it will work fine..
Old Nov 15, 2005 | 10:34 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
yes it's a one piece. thanks. If anyone else has input please chime in.
Old Nov 15, 2005 | 11:30 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
All 1986+ Gen I & II SBC cranks take the same flywheel including LT1, and LT4. Therefore yes, your ZZ4 engine has the same back end & flywheel requirements as an LT1; you're good to go.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
