Rear Gear Swap Q's
Old Nov 17, 2005 | 04:04 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Rear Gear Swap Q's
Winter just arrived here in Ohio, so its time to get busy on the cars for next year!
First Im gonna put 3.23's in my Trans Am. Has 2.73 10 bolt stock, so I need part #RMG-4900031 from Summit, right?
Now what do I need to correct the speedometer? Its the electronicaly controlled version.
Old Nov 17, 2005 | 07:15 PM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
Re: Rear Gear Swap Q's
SGI-5 from Dakota Digital fix the speedometer.
I am not sure about the part though. I put 3.73 in mine so it is a little different.
Old Nov 17, 2005 | 08:46 PM
Shake Zula's Avatar
And thats around $80? Do I need to buy anything else with it?
Old Nov 17, 2005 | 11:18 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I was looking to do the swap but 2.73s are 2 carrier series and 3.23s and 3 carrier series so you need to change that as well. I couldn't tell you what that means, but that's what I've been told many times.
Old Nov 18, 2005 | 02:01 PM
Shake Zula's Avatar
That part number I listed is specificaly for the 3.08 and numericaly lower carriers.
Old Nov 18, 2005 | 05:45 PM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
If you are replacing the axles you can upgrade to a series 3 carrier. If you are keeping the stock axles then you need to get a carrier to matcu.
When I did mine I went ahead and dove into new moser axles for $240.00.
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
