POSI broke???
Old Nov 26, 2005 | 10:15 AM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
POSI broke???
Something wierd just happened....Brought my bud on a test drive and did a little burn out...TWO TIRE MARKS (I have POSI) but as I left his house I did an EXTENSIVE BURN OUT and only ONE TIRE MARK (Passenger side). I called my bud up and he said that the driver side tire was not even spinning. Is this a sign of POSI wear in the rear or is there some thing in the rear that locks up as soon as you go forward ( I backed out of his driveway and crawled forward about 2 feet before the ONE TIRE DISPLAY...)????? Maybe the car has to go forward a certain footage until the posi locks up????
Gimme some input
Later
Old Nov 26, 2005 | 11:34 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Sounds like u either need to re shim the cones or replace them in your 9 bolt rear.
Common occurence do some searhcing here and u will find detailed info and photos
later
Jeremy
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
