Rear end is confusing me...
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
well on the 84 Z28 that i just picked up a few weeks back im very confused about the rear end in it.
The RPO codes for the rear are GU5 and Y06
3.23 gears
9.5" saginaw
Correct me if im wrong but isnt the 9.5" a 14 bolt 33 spline rear?
I have never heard of a 14 bolt from the factory...
3.23 gears
9.5" saginaw
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My truck has a 14 bolt 9.5" ring gear but it's a truck diff and was never offered in any car.
GU5 = 3.23 gears
Yes Y06 means a 9.5" ring gear but your car does not have that. You have a 7.5" ring gear 10 bolt diff.
GU5 = 3.23 gears
Car: 87 IROC L98
Don't believe everything on the rpo decal. Anything could have been changed although I have no idea why a third gen would have a Y06 code unless it's actually something else and just looks like Y06 or for some reason third gen's have a different meaning for Y06.
When in doubt, look at the actual part to see what's on the car. The axle code is at the front of the passenger side tube near the center. Some cleaner and a wire brush can pull the code out eventually but even then that doesn't mean someone else hasn't changed what's inside the diff.
My car originally had a 3.27 gear 9 bolt. The only codes listed in the glove box that were related to the diff are:
GW6 = 3.27 gears
G80 = posi
No other codes were specific to the diff however the 9 bolt diff probably fell under a group package code such as the IROC package or performance package. My car had no Y0x codes at all.
GW6 = 3.27 gears
G80 = posi
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
I should phone them up and raise hell because my RPO sticker says i have a 14 bolt truck rear in my car
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
lol
yeah the 9.5" was the semi floater 14 bolt in 81-up trucks
some 6 lug and most 8 lug
well GM was good with re-using RPO codes sometimes
its no wonder
lol
3.23 is the little baby 7.5" axle of course
good luck
its no wonder
lol
good luck
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
