700r4 Part Compatibility
Old Dec 4, 2005 | 12:22 PM
Crafty's Avatar
Converting '87 MAF to 90 SD. I've got a '90 SD harness, but the trans only has a 2k VSS.
I've read here that by changing the prom and repinning the harness I can run a 2k ppm on a 730 ECM ? The car wont have cruise and the dash will probably be a custom unit from dakota digital that I guess I can run on the 2k output from the ECM ?
If the above is not possible can I just by the 4k VSS and bolt it in to the trans or do they use different wheels inside the tailshaft ?
To put it another way, will the magnetic type VSS "read" the gear wheel inside an '87 trans ?
Old Dec 5, 2005 | 09:14 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if the '87 trans has a reluctor on the shaft, then yes it will. my '87 trans has a gear drive on the shaft and the vss is on the back of the speedometer housing. you can pull the tail housing off the trans and replace the gear with a reluctor and the proper vss for the speed density set-up and go with that. but no, the magnetic type vss will not read off the gear wheel inside the '87 trans. it has to have a reludtor/pick-up to read off of.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
fonzie85
Aug 13, 2015 11:50 AM
1nastygta
Aug 8, 2015 07:38 PM
