t5 rebuilding
Old Dec 9, 2005 | 03:52 PM
Big4x4Ride's Avatar
t5 rebuilding
going to rebuild the t5 i bought for my ride, the cluster gear and maindrive are toast. can it be upgraded to any WC parts I have an 83 model tranny so its non WC
basically can i swap in a WC cluster and mainshaft??
Old Dec 10, 2005 | 10:38 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
if you do a search there a lot of info but i'll answer anyways
no you cannot put world class parts in a non world class case and vice versa
i wouldnt rebuild a t5 again with a t56 in the world.
Old Dec 15, 2005 | 12:15 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
NWC T5s are basically boat anchors. If you can get a WC then yu can upgrade it with superalloy gears or G-Force gears and make it as strong as a T56.
Parts are not interchangeable between the two designs.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
