$200 for a used rear end???
Old Dec 12, 2005 | 07:39 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
yea thats what my local jnk yard said $200 for a used rear end with drum setup,.,.,.,.isint that a little to much?? and other then that ill have to drive over 70 miles to looke down the hill for one.....
Maby ill just ask around on this web site...
Old Dec 12, 2005 | 08:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i would only give that much for entire parts car
not for just a 7.5 rear axle
you should be able to find a parts car laying around somewhere for that much or less, `82-90s
good luck
Old Dec 12, 2005 | 09:27 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
check with mark@hpsalvage.com. He might have what you need and it will be with disc brakes. I can't give a price becuase he has several different gear setups and years.
Old Dec 13, 2005 | 01:29 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
The most I would pay for a used 7.5" is $150, and that is only if it is posi and disc brakes. Hawks third gen might have one. That is where I got mine a few years back.
Old Dec 13, 2005 | 01:45 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
200 maybe for a thirdgen rear complete with everything and disk brakes or one with very low mileage on it, especially the later 28 spline axles and 7.625 ring gears
4th gen 10 bolts go 250-300 complete, always an option for good disk brakes
Old Dec 15, 2005 | 10:21 AM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
No i would not pay that much because i know where i can get a whole car for $250 and that has motor (no good but its TPI), tranny (probably worn out), and the rest of it.
Old Dec 16, 2005 | 05:20 PM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
Re: $200 for a used rear end???
That is a little much!!!
Unless it is POSI, DISC BRAKES, LOW MILES, and ALL THE PARTS.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
