Flywheel for T56...
Old Dec 16, 2005 | 10:56 AM
nothingssafe's Avatar
Car: 86 TA
Flywheel for T56...
Well, my trans is just about dead, and I have the old T56 laying around from my old car. I know everything else I need for the swap, but what flywheel? It is the original engine in my 86.
Sean
Old Dec 16, 2005 | 12:17 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Centerforce or McLeod. You've got a 2-piece RMS and a T56, so you need a custom flywheel. It will be a 153 tooth flywheel, so make sure you've got the right starter (staggered bolt pattern).
Old Dec 16, 2005 | 12:47 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Heres the Centerforce Flywheel on Summit Racing so that you dont have to search too much.
http://store.summitracing.com/defaul...=egnsearch.asp
What are you planing clutch wise?
Old Dec 17, 2005 | 01:56 AM
Car: 86 TA
I have an LT4 starter that is practically brand new. Will that work? Where can I purchase a McLeod flywheel and which of the two do you recommend?
I have a brand new LT1 disc with a new LT4 PP.
Old Dec 17, 2005 | 05:28 PM
Clutch_Grabwell's Avatar
Car: 1986 Monte Carlo SS
Engine: 1989 L98
Axle/Gears: 8.5" 3.42:1 posi
Re: Flywheel for T56...
Originally posted by nothingssafe
I have the old T56 laying around from my old car... but what flywheel? It is the original engine in my 86.
Your '86 should have a 1-piece RMS. The flywheel that came with the T-56 will work.
Old Dec 17, 2005 | 09:02 PM
I bought my McLeod flywheel from Summit I think, or maybe it was PAW. Get the steel one. I used the aluminum one and was not happy with it. Too light to keep any interia going in the engine, makes it a little bit of a chore to drive ont he street.
As far as RMS go, check before ordering. There's no way to be 100% certain without a visual verification. My '86 had a 2-piece RMS engine.
Old Dec 18, 2005 | 10:41 PM
Car: 86 TA
Does anyone have a definite answer? Its not exactly something I can just pull apart and see what one I need. I need to get this swap done in 1 day since its my daily driver...
Old Dec 19, 2005 | 11:41 AM
Engine: 1989 L98
Checking before ordering is really good advice.
Does anyone think it's possible to verify your RMS type by removing the inspection cover?
Old Dec 20, 2005 | 10:51 AM
I would think that if you had access to the casting numbers for the block you could determine it, but otherwise it's a crap shoot. I don't have casting numbers on anything that new, or production (I have them for Bow Tie and service replacement blocks though).
Old Dec 20, 2005 | 02:34 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You could pull off the inspection cover & look to see if the cast aluminum housing that holds the 1 pcs RMS is there. You may need a mirror to see up there.
Old Dec 21, 2005 | 09:23 PM
Yeah, you could try that, or measure the width of the oil pan where it mounts to the block. The 1-piece motors have a much wider scallp in that area to clear the seal adapter.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
