rearend rebuild
Old Dec 16, 2005 | 11:04 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
rearend rebuild
I am thinking about getting the rearend in my car rebuilt or doing it myself and was wondering how much i would be looking at to bring it back to say like a bit better than stock with a limited slip or something related? i am not wanting dragstrip level stuff cause this car is never going to have bigger than say mabe a 3.4 and from what i have read even taking that engine to its limits will only get like mabe 300hp or so maxed out with turbos and stuff. so whereabouts would i set on cost? i want to replace everything that wears out. I have looked around but i have not found any whole rebuild kits in my searching.
Old Dec 20, 2005 | 01:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
look for a stock posi from a JY, it'd be cheaper then buying a new one ($450)....
I'm rebuilding my rear now, it doesn't require a lot of super special tools (although i'm having a hell of a time removing the carrier, i'm getting a gear shop to do that for me...).
If you swap gears you'll need a dial indicator and magnetic base. (or I guess if you install a posi).
you may need outer axle bearings (aka wheel bearings), and seals, $60 or so. If you replace ALL the bearings in the rear, it gets expensive, as there are like 6 bearings total, about $20 per.... you can get a rebuild kit, for $120 or so.... Check rockauto.com, I know they have a kit on there, you can at least get a p/n and see what's in the kit and go from there.
if I were you, i'd just get a posi rear out of a late 3rd gen, and replace only what's needed (seals, fluid). That should last you.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
