700r4 to 4l60e
Car: 88 Trans am
Engine: high comp vette engine.
Axle/Gears: 308
700r4 to 4l60e
i need to know what i need to swap my old tranny to a 4l60e. my friend has a 4l60e for $60 rebuilt but it was in a blazer so it has a transfer case on it what do i do to make it work in my car.
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
for the 4x4 trans you will have to swap the output shaft to make it work with a car driveshaft and then you will need a computer to shift the trans. TCI makes a retro kit for this, I believe it's called the T-COM. I am assuming the blazer was at least a 4.3L or the trans won't even bolt up. Plus, if you are putting a V6 trans behind a V8, the internals won't last long.
Engine: LT1; LT1
there are fewer clutch packs for the V6 trans which means less holding power and faster wear on the internals. It will work, but it is not recommended.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
