9" rear, dirveshaft
Old Jan 4, 2006 | 04:15 AM
rocz's Avatar
Car: 88 IROC-Z 91 RS
Engine: 358 in the roc 305 in the rs
Transmission: 700's
9" rear, dirveshaft
does the stock driveshaft fit with a 9" rear
Old Jan 4, 2006 | 07:04 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The pinion is lower on a 9", so the drive shaft needs to be a little longer. Also Ford pinion yokes usually take 1330 or 1350 Spicer U-joints & will not work with GM Saginaw joints. A conversion joint can be bought at NAPA & other auto part stores.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
