What Flexplate Do I Need?
Old Jan 7, 2006 | 08:25 AM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
No one Ive asked so far realy knows what flexplates I can use.
I have an 87-later 1 piece rear main seal. Im puting in a TH350, and will be using a TCI convterter thats says "dual bolt pattern only" ( but for all I know thats just in hope that people buy their flexplates along with it)
I have a flexplate from a 700r4 that my engine originaly had. Also have the starter for it.
Will that work? Or do I specificaly need a "168 tooth, dual bolt pattern" And some say "counter-balanced" should that be of concern to me?
Old Jan 7, 2006 | 11:39 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Assuming you have a 350 or 383 with internal balance, 153 tooth, neutral or internal balance, one piece rear main seal
Summit part# for B&M BMM-20238 & has 10.75" bolt pattern
168 tooth is BMM-20239 & has 10.75" & 11.5" patterns.
Dual bolt pattern refrers to Powerglide & Hydra converters.
Old Jan 7, 2006 | 12:29 PM
Shake Zula's Avatar
ok... not exactly an answer to my questons....
I need to know if a 153 tooth flexplate from a 700r4 will work with an 86 Th350 with a TCI converter. If the converter bolt holes line up with the ones on the flexplate it should obviously work,right?
Old Jan 7, 2006 | 02:02 PM
Ricktpi's Avatar
It should fit.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
