torque convertor lock-up
Old Jan 7, 2006 | 04:26 PM
jeremys82c10's Avatar
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
Axle/Gears: 8.8 w/3.08's with a trac-lock
i might be going to be driving a vehicle that has had the ecm taken out of it , so the torque convertor won't lock-up, the only thing that will happen is lose some MPG's on the highway isn't it
Old Jan 7, 2006 | 04:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll lose mileage and the transmission will run hot.
Old Jan 7, 2006 | 06:14 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I've got a converter lockup kit from Dr. Evils Trans, yea I know crazy name, but it was cheap enough and works. My car has no ECM either but I run a 700R4. It uses a pressure switch with only a 2 wire hookup for it.
Old Jan 8, 2006 | 01:21 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
There are a couple companies that make the lockup kits. I would not recommend running it without something like this to control lockup.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
