2.73 to 3.73
Old Jan 8, 2006 | 09:10 AM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
2.73 to 3.73
I plan on puting 3.73 gears into a rear that has 2.73 in it now. Will this work, or will I need a spacer for the gear.
I also want to get a new posi unit but have no clue what will work for my application(just street driving) Auburn, eaton, powertrax, etc....
Old Jan 8, 2006 | 07:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You can use a spacer or get a 2 series 3.73 gear set.
I have an Eaton and it is a very good posi.
If you are only street driving it and not auto-x'ing then you could also go with the Zexel Torsen, and since it is a gear based posi it won't wear out as fast as an Eaton or other clutch style posi.
I had the zexel torsen and it worked awesome on the street, just sucked on the auto-x since I'd have a lot of inside wheel spin when cornering hard and getting on the throttle, so I went with an Eaton.
Old Jan 8, 2006 | 09:32 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
if you are going to get a new posi then you don't need a spacer. just buy a 3 series posi unit and buy your 3.73 gears.
Old Jan 10, 2006 | 02:15 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
I want to do the same thing to my car. So if I have 2.73 ratios and the want to go 3.73, I just get the 2 carrier set and thats all I need to do? Thanks, randy
Old Jan 10, 2006 | 09:14 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
if you just want to change the gears, then yes. if you are doing a posi unit and gear change then just buy the 3 series gears and unit.
JSDaddy189
Sep 26, 2015 03:50 PM
64Chief
Sep 12, 2015 08:05 AM
whyt86roc
Sep 10, 2015 10:03 PM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
