good t5 replacement
Old Jan 12, 2006 | 04:37 PM
nic_brestel's Avatar
Car: 91 Z28
Engine: 383(Race Engine)
Transmission: m5
good t5 replacement
My is my best replacement option for my car. I have a 91 z28 with a 4bbl 383. About 500hp 450lbs of tourque. I know the t5 wont hold up. I want to keep to keep it a manual trans. Is a t56 my only option. The easiest to bolt in would really help.
Old Jan 12, 2006 | 04:44 PM
CrazyHawaiian's Avatar
Car: too many ...
You could have the T5 built w/ stronger internals (like G-Force)and it would be a direct swap. Or you could do the T56 swap, even a TKO swap, those might require slight modification. But if its already a manual then its gonna be easy. Its the auto to manual swap thats a PITA.
Old Jan 12, 2006 | 09:34 PM
Car: 91 Z28
Transmission: m5
Where do i go to get stronger internals for the t5. I have always delt with automatic transmissions. How much would it cost? What are the torque ratings?
Old Jan 13, 2006 | 11:35 AM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
the g force internal gears will hold up to approx. 500hp/500ft lbs according to people on this site.
go to www.g-forcetransmissions.com this is their website most people say its about $1,000 to do the gear swaps however i don't know because i haven't done it only did research of what others have told me.
F-body-fan
Jan 12, 2023 01:49 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
