speedometergear
Old Jan 15, 2006 | 02:08 PM
jakecamaro's Avatar
speedometergear
I have a t-5 nonworldclass transmission that has a electronic gear.I need to know how to change it to a cable.
Old Jan 16, 2006 | 10:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Unscrew 10mm bolt holding electronic speedo. Pull out electronic speedo. Watch out for fluid if tranny is full. Insert cable speedo unit with correct gear on it. Insert 10mm bolt and tighten.
Old Jan 18, 2006 | 11:06 PM
jakecamaro's Avatar
I am already that far. What i need is a part number for the correct speedometer sending unit that plugs into the transmission. The sending unit I have is the magnetic pickup style. The tranny is non worldclass out of a berlinetta so Possibly an s-10 sending unit could work? Any help would be greatly appreciated.
