Flywheel ???
Old Jan 25, 2006 | 09:20 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
Flywheel ???
I am building a 383 stroker and i received a new flywheel and i was wondering if the weights that are welded to it on one side matters what side faces the engine. Basically are the weights supposed to face the engine or the tranny.
Thanx NICK
Old Jan 25, 2006 | 11:34 PM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
I believe you want the side with the ring gear towards the motor. Otherwise you wont be able to start the thing.
Old Jan 26, 2006 | 10:03 AM
Engine: 383
Transmission: th350
Is the ring gear the weight looking thing? I have the weight faced in twards the engine. Thanx for the reply
Old Jan 27, 2006 | 05:03 PM
0514rob's Avatar
Car: 88 GTA
Engine: 5.7L
Transmission: 6 speed swap
Do you have a flywheel or a flexplate there? Flywheels are for standards, and flexplates are for auto trans.
Old Jan 27, 2006 | 06:46 PM
Engine: 383
Transmission: th350
Woooops brainfart i have a flexplate for my 700r4 and the weight welded to it is twards the engine, Is this right sorry to repeat it again.
Old Jan 27, 2006 | 08:52 PM
0514rob's Avatar
Car: 88 GTA
Engine: 5.7L
I'm away on business right now but If I remember correctly, yes the balancing weights do face towards the engine. I will look at one of my engines when I get home on Sunday if nobody has replied on this yet. I just wanted to help clear up the flywheel flexplate thing for ya after seeing some confusion brewing . Cheers!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
