flexplate
Old Jan 29, 2006 | 07:17 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
flexplate
i have a 88 iroc 305 tpi with a 700r4. i bought a 355 2 piece seal and they told me to get a internal or neutral balanced fiywheel does any one no how many teeth i will need so i can order from jegs or summit
Old Jan 29, 2006 | 08:50 AM
ede's Avatar
ede
all SBC except the 400 were internal balanced. the SBCs with a one piece crank seal had a weight attached to the flex plates, but it didn't change the fact that they were internal balanced. i always get the teeth count screwed up, but i'm think 168. i'd just call and let them figure out which one you need. all you need to know is the engine and a year, and with 350 you can say anything before 86 and be good.
Old Jan 29, 2006 | 01:58 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Stock Flywheel is 153 teeth for your engine.
Old Jan 29, 2006 | 04:37 PM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
flexplate
thanks,just called jegs and got what i needed
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
