Posi not working
Old Jan 30, 2006 | 06:04 PM
91 z28 350's Avatar
Car: 91 Z28
Posi not working
My posi well actually limited slip has been working fine and now all of a sudden if i do a burn out im only pullin one leggers. Could low gear oil cause this or is my diff broken ? i jacked the car up yesterday and spun the tires and didn't here any noise coming from the diff. I did replace the diff cover not to long ago i added limited slip fluid and filled it up with gear oil.
Old Jan 30, 2006 | 07:24 PM
91 z28 350's Avatar
Car: 91 Z28
If it ends up being the diff what replacement should i get eaton or auburn
Old Jan 30, 2006 | 10:47 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
well no.1 it's probably the clutches i think thats what it has or the springs in the center of the carrier. if you want to get a little more life out of it change your rear oil and dont add the l-s additive. it's meant to make the clutches slip... must likely you'll have to get a new one or take it apart and replace the clutches. and i believe eatons are factory in the ls1 cars
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
