700r4 shifting at 4000rpm???
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
it sounds like the valve is sticking. i was able to get mine "unstuck" by unhooking the cable from the carb, putting it in reverse and pulling it back and forth hard several times. try that before you spend any money on it.
Engine: 427 454
Transmission: TH400
yes, it would not shift until 3500-4000 rpm's with a new tv cable.
with it in rev. and idling, pull the cable out. you should hear the engine rpm's drop like you are putting it into gear. if you don't then the valve is stuck. it took 10-15 times of pulling it but it finally worked and i have not had any problems since then.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
