Converter Sideplay???
Old Feb 9, 2006 | 11:44 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Hey just a quick question.
I took out the stock converter in my 87' GTA to put in a Pro Yank 3400 lockup.
I noticed that if I shake my stock converter in a side to side motion the things inside move back and forth. Is this normal or something to be concerned about?
Also, If I stick my finger in the converter hole and press on the gears sideways I can move it about 1/16-1/8"ish.
Note: This is about my stock converter.
Opinions??
Old Feb 10, 2006 | 07:35 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I wouldnt worry about it. The input shaft keep everything located. Ive noticed the same thing on all the ones Ive handled. The assembly inside will move around little when not installed on the transmission.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
