2.73 to 3.42 gear ratio swap
Old Feb 14, 2006 | 08:21 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
ok so i've searched and searched for like 1hr30 and i can't find exactly what i needed. So far i've know that i need a gray 15 tooth and yellow 41 tooth. So that the speedo reads correctly, but what do i need for the accuatly swap. By the way i'm going from a one-wheeler to posi. car is a 92 camaro rs 305TBI
Old Feb 14, 2006 | 09:22 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
there are alot of form here on the subject herhttps://www.thirdgen.org/techbb2/showthread.php?s=&threadid=346226e is one this sould be the same just different gears
Old Feb 15, 2006 | 06:04 PM
v8unleashed's Avatar
Re: 2.73 to 3.42 gear ratio swap
You need gears, a posi and an install kit and someone who knows wtf he's doing.
You can get the gears and kit from anywhere, as long as they're for a GM 10 bolt.
SLP may or may not still sell their takeout posi for like $100. If not, it was a great deal while it lasted.
BTW, it's sort of funny, you have the same car as I do (except I have a firebird), you're making the same swap I did and are asking the same questions as I did at about the same age as I was.
Old Feb 15, 2006 | 06:28 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
In both of my firebirds I went from 2.73 to 3.42. I think its easier and cheaper to just swap out rearends. Also I bought both my speedo gears from ck performance. You just call and tell them what trans you have and the gear ratio and they figure it out and send it to you. I think its about $45 bucks shipped to your door.
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
