Do I have 3.73 or is my drivetrain messed up
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
I have a 91 RS. Supposed to have 2.73 gears. Calculator says at 70 mph with 13inch radius tires, 0.70 4th gear, and the 2.73 I should be at 1728.7 RPM. HOWEVER, in reality, I'm at around 2400 rpm at 70mph. The calculator says at that RPM with that tire radius and trans. gear, its more fitting of 3.73 gears (2361 RPM).
The trans shifts fine, it has slipped once (on a 4 to 2 shift) in the past nine months, but has shown no other problems, with 108,000 on the odo. Also, it does shift through all four gears. Is there a problem with my trans or is it at all possible to have 3.73s.
Car: 91 RS, 95 Z28
I want to add that, according to title changes on Carfax, I am the fifth or sixth owner. No other apparent mods, but the car is very well maintained.
If your rearend is stock and untouched, you definitely have 2.73's. However, if anyone did change the gears before you owned it, the only way to know for sure is to pull the cover and find the ratio that's stamped on the back of the pinion gear or the side of the ring gear. There will be two sets of numbers with a colon between them (ex. 3.73 is 11:41). You just divide 41 by 11 to get the ratio.
Car: 91 RS, 95 Z28
DAAAAMNNN. I wish I'd have known that two days ago, I just changed the diff. oil.
Nex time
Nex time
First thing is, what makes you think your engine is at 2400 RPM while driving down the road?
Is this the number that waving-around thing the factory put in your dash is covering up? If so, it's probably wrong; like most all the rest of them. THey're not "instruments", they're just interior trim, to help augment the sporty image. After all, no car can truly be a "sports" car without one of those, right? Doesn't matter if it means anything or not, it's just gotta wave around when you give the car gas. Then it's all good, and the car is a "sports" car. Ask any Honduh driver.
Before getting all worked up and excited about gears, check your engine RPM with a piece of REAL test equipment. The most likely explanation is that your gears are stock (since they cost LOTS of money to change) and your tach is broke (since the tach breaking is free). Knowing typical car owners, I know which one I'd bet on.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Sofakingdom has pointed out the most probable cause but you may want to consider the most dangerous one as well. No matter how long you run with a busted tach it will never result in a $1000 transmission rebuild.
I do like that guy though.
Car: 91 RS, 95 Z28
I'll admit I'm being too optomistic about this.
Also, I exagerated, its 2200 rpm at 70 mph (according to that wavy thingy
).What is the "REAL" test equipment you're talking about? Are you talking about an aftermarket tach?
Converter lock up working?
THey shouldn't charge you more than a few minutes labor to just hook up to your car, and give you the real engine RPMs vs your tach readings; i.e. hold the engine RPM to where the dash tach says 1000 RPM, give you the real RPM; hold the engine RPM at 2000, give you the real RPM; etc. Up to 4000 or so should be enough.
The way these tachs fail is, they read proprtionally higher. As they age, they read higher and higher. Say, it turns out that your engine is actually doing 800 RPM when the factory trim package reads 1000; and 1600 when it reads 2000; and 2400 when it reads 3000. That's 20% at all RPMs. It's not like they're "500 RPM off" like some people say, which would be sort of like having "zero" offset from zero.
I've seen these as far as 100% off, and still "appear", to the eye, to be working normally; i.e. reads 2000 when the real RPM is 1000, reads 4000 when the real RPM is 2000, etc.
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
well my car runs 3000 on the dot at 70 and it has a 2 month old Equus Tach. is that what it should be running?
how about you place a jack under the differential housing and jack the car up, place jackstands under the LCA axle mounts. put the car into neutral and count how many times the driveshaft turns to make the tire do one complete revolution. that should give you a good idea of the gear ratio. i did this on my car and got almost 2 3/4 turns which means i have 3.73's (and ive verified that by looking at the ring gear)
Check your lockup by tapping on the brakes while keeping the throttle at highway speed cruise or gentle acceleration. Brake switch will disengage lockup and cause an rpm flare of about 200-300. If you've been cruising without lockup your converter slip allows the engine to turn at a higher rpm than needed...>0.70 through trans to rearend.
Car: 91 RS, 95 Z28
Car: 91 RS, 95 Z28
Hahha, its cool. Wow, i was freakin myself out trying to figure out how 2 3/4 led to 3.73.
Car: 91 RS, 95 Z28
I just got my ALDL cable and I thought I'd update.
I do have 2.73s, and my actual RPMs are MUCH lower than what my tach is telling me.
At idle, tach reads about 800, actual is 650.
At 4,000 rpms on tach, the engine is actually just breaking 3000 rpms.
It is off by 1000 rpms. That is ridiculous.
Car: 91 RS, 95 Z28
Originally Posted by rwdtech
did u ever try the driveshaft spinning thing?
I just brought this thread back to life to let people know how misleading the stock tach is.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Originally Posted by sully91rs
Yep. That is what I did to find out I have 2.73.s I also did it on my friends 86 v6 camaro, and it has 3.42s, which is what it should have.
Car: 87 GTA
...with 13inch radius tires...
Engine: 2.8 MFI
i redid the TV cable adjust ment and my RPMs dropped from 3000 to 2500 at 70! holy crap im surprised that my trans hadnt burnt itself out since i had put 5000 miles on it that way. Gas mileage went up a lot to.
