HELP 1987 Firebird TransAm 305 4 brl 5 speed manual, what type of fluid?
Old Feb 18, 2006 | 05:49 PM
xtmanx's Avatar
Just put the new clutch and flywheel in and i need to know what type of fluid, can anyone help?
Transmission fluid that is
Old Feb 19, 2006 | 12:03 AM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Apparantly you can use either ATF or Gear oil assuming non world class. When I researched it a while back, I found out that GM couldn't make up their mind and switched between the two throughout the years. If you have a World Class tranny use only ATF though.
I have a non world class and ended up using ATF with a quart of Lucas to thinken it up a bit. That would be my recommendation.
Old Feb 19, 2006 | 12:54 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Agreed. My '87 owners manual reccomended ATF for my 5-spd.
Old Feb 20, 2006 | 10:32 PM
xtmanx's Avatar
I read that 87 was the only year they said to use 5w-30 motor oil in the trany?
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
