need correctt flywheel
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
i have an 84 trans am..orginally a 5spd car
i just swapped in a 1970 350 with a 2pc rms
aparently my short block was changed at some point to a 1pc rms so i needed to get a 2pc rms 153t flywheel to make the new engine (1970 350) work with my trans
i tried to order a ram flywheel from summit 153t 2pc rms but it is quite a bit thinner than my stock flywheel and i think this will cause problems with my clutch not having enough disenguagement...(hydralic clutch- no adjustment)
my local parts store cant get the flywheel and i need a stock one..
any ideas?
any ideas?
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
14085720 is the GM part#. Order one from your favorite GM source, local dealer, GMpartsdirect.com, etc.
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
