700r4
Old Mar 4, 2006 | 03:26 PM
350/350's Avatar
Car: 85 Camaro
700r4
I had my 84 Camaro sitting for a month and now I start it up the trannsmission does not have any power when I floor it takes a while for it to speed up I, checked the fluid and it's ok but when I hit 25mph it sounds like it wants to die out
Old Mar 4, 2006 | 03:53 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
does it down shift when you pull the shifter to 1st?? (maybe 2nd or 3rd gear start)
does passing gear work?
do all the gears work??
if so, sounds like the torque converter one way roller clutch is broken. will take a new converter.
make sure your parking brake isn't stuck on, too. wiggle the cables, make sure the rear wheels spin free off the ground in neutral with the engine off.
....lots of possibilities
Old Mar 4, 2006 | 03:54 PM
350/350's Avatar
Car: 85 Camaro
700R4
All gears work
Old Mar 8, 2006 | 07:42 PM
greggbruce's Avatar
Re: 700R4
Originally posted by 350/350
All gears work
my educated guess is the torque converter took a dump. time for new one.
check the filter, cut it open, if there's more than just a teeny amount of junk in it, time for an overhaul and new converter....
Old Mar 10, 2006 | 04:59 PM
1992camarors's Avatar
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
Replace your 700r4 with a 1987 or newer one b/c many uprages were added by gm to improve the performance of the 700r4. Thats what I would do considering that the 700r4 before 1987 were weak.
Old Mar 10, 2006 | 08:28 PM
greggbruce's Avatar
or, if you know what you're doing, (professional), you can change the internals in the right combinations, to match the 87 and up.
I have done it many times.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
