B&M 700 to 350 changeover insturctions
Old Mar 12, 2006 | 03:52 PM
camaronut79's Avatar
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
I need the instructions on how to put in the b&m changeover bracket.
thanks
steve
Old Mar 12, 2006 | 04:03 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
are you talking about the B&M tarque arm bracket for the 350 turbo?
I had one On a car a few years ago, it was the bigest joke Ive encountered. there was a million holes drilled in it from the factory and none of them bolted up to the torque arm bushing mount. it bolted to the tranny fine and that was it. I had to drill my own holes in it for it to work. If I ever did another swap that required one I would fabricate my own. its just a flat peice of steel that has some bends and some holes. piece of crap if you ask me.
Old Mar 12, 2006 | 04:12 PM
Car: 1983 z28
Transmission: th350
yes the b&m th350 bracket. unfortunately im not a fabricator an cant whip up brackets although i would like to be able to.its not on the b&m website I looked all over.
Old Mar 12, 2006 | 05:54 PM
90iroc5spd's Avatar
well then as far as bolting it on its not hard. take the four bolts from the tailshaft housing and the bracket bolts on there using those bolts. then your best bet is gonna be to install the tranny and see where the torque arm mount hits on the bracket and drill holes to bolt it on. thats what I had to do, it wasn't all that hard.
when you drill the holes, your gonna have to get the height of the torque arm right though or your pinion angle will be off. use the stock mount and tranny as a gude to help ya
Old Mar 13, 2006 | 10:17 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Here are some pics that might help.
Old Mar 13, 2006 | 10:43 AM
Blackroc86's Avatar
Car: 1986 Iroc
another one.
Old Mar 13, 2006 | 10:45 AM
Blackroc86's Avatar
Car: 1986 Iroc
one more.
tonys91rs
Oct 10, 2015 03:31 PM
84 TA NV
Sep 6, 2015 08:02 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
tonys91rs
Sep 2, 2015 07:07 PM
