Does Anybody Have A Moser 12 Bolt with OEM Rear Brakes?
Old Mar 14, 2006 | 02:42 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Want to put an aftermarket rear on my 92 but all the mfg's(Moser,Currie) say you need to use 93 and up brakes. But i want to use the OEM Baer Brake setup I have. What to do?
Old Mar 18, 2006 | 06:54 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I have a moser 9 inch with stock 87 rear disks, the backing plate had to be re drilled for the ford big bearing housing ends..(probably the same housing end they use on the 12 bolt) aside from that it all bolted on, just have the plates ready so the can put them on before they press the bearings onto the axles..or do it yourself to be sure..and make sure the axle flange diameter is good for rear disks too.
Old Mar 19, 2006 | 03:39 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Yeah I opted to go with the Moser 9" with 35 Spline axels. I was told to counter sink the backing plates and everything else should be good to go.
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
kyleb24
Aug 15, 2015 08:24 AM
