swapping to disc rear end and need some help
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
i am going to get a rear from an 87 Z28 that has a 3.23 ratio and disc brakes and is posi...I have a 92RS 305,T-5 my rear is a drum, peg leg with a 3.08....will i have to change my master cyl or the proportioning valve for the disc to work right or is it a bolt in application.....and will this affect my speedo and if so is there a correction for it...thanks for any help and if there is a thread here to help me please point me in that direction
Axle/Gears: 3:08
will the master cyl work...the reason i ask is because they are two diff part# at the parts store for the two cars...and thanks
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
You don't have to change anything. Its personal preference of how far you want to push your brake in.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Like 91banditt2 says, you should change the proportioning valve. Otherwise, the rear brakes will not be as effective as they should be.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
