T-56 Flywheel???
Old Apr 5, 2006 | 12:25 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
T-56 Flywheel???
Ok, I'm hearing numerous different things and my motor is at the machine shop getting balanced. What flywheel do i need? The motor is a 1989 1 piece rmc, out of a suburban. I will be using a T-56 transmission i have at my house. I need a 153 tooth, correct? I need some different part numbers for what i need so i can order this asap. I would really appreciate the help guys.
Zach
Old Apr 5, 2006 | 12:40 PM
Forget all that extra drivel about teeth and 1-pc.
You just need a stock flywheel for a 93-97 F-body V8 w/6-speed. Assuming of course, that that's what kind of a T-56 you have. You could use a junkyrad one, new GM, aftermarket, etc. As long as it fits that kind of car.
Don't outsmart yourself. Just look it up by application.
Old Apr 5, 2006 | 12:57 PM
Car: 91 Firebird
Engine: Turbo 355
Ok, my new motor will be pushing around 420-440 rwhp. Can i go ahead and order a stock replacement flywheel?
Zach
Old Apr 5, 2006 | 01:21 PM
Car: 91 Firebird
Engine: Turbo 355
Anyone?
Old Apr 5, 2006 | 03:13 PM
That's what fits. Assuming of course that it's a stock T-56 out of a 93-97 F-body.
Is there some kind of reason that it might not, that you haven't told us about?
Old Apr 5, 2006 | 09:27 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
The only thing you will need to worry about is internal balanced vs external balanced on the flywheel. Stock = external balance, which means that one side of the flywheel will have weight added to it stock style or it will have some weight removed from it aftermarket style.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tonys91rs
Oct 10, 2015 03:31 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
