Bad TC? Help.
Old Apr 10, 2006 | 02:12 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Bad TC? Help.
My 92 has 63k miles on it. Just recently I started feeling a thunk when the TC locks in D and OD under load(meaning anything more then slow acceleration). It will also thunk when it unlocks(Going up a hill). Now in reverse the transmission "whines" on and off.. not a good sound. My question is, is it possible it's just a convertor gone bad? Perhaps the bolts on the convertor are loose? Thanks.
Old Apr 11, 2006 | 07:55 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Yes to both questions. Look at the flexplate when you are under there. Be sure it is not cracked. The converter has an internal endplay spec. It can be checked by a shop with the proper equiptment. .024 is the max allowable end play for a 30 spline converter.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Numbah-1
Sep 12, 2015 08:57 PM
Keiffer76
Sep 9, 2015 08:52 PM
