shift selector help
Old Apr 21, 2006 | 06:56 AM
stevog66's Avatar
Car: 1984 F-41 Camaro Sport Coupe
Engine: LG4 V8
Axle/Gears: stock
shift selector help
lately noticed that my shifter doesn't have any resistance when put into gear,then last night won't shift to park but all other gears work.in other words my car should be in park but it is in reverse etc...Is this a TV cable problem?Linkage?
Old Apr 21, 2006 | 08:21 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Without question you need to check your shift cable. Theres one end at the transmission, driver side, right next to the pan, one end under the shift plate (3 bolts, one is under the ashtray the others are just aft of the shifter handle.) Take off your T-handle shifter by using needle nose pliers on the front side of the handle, theres a clip inside the slot that has to come out, then the t handle comes off. This'll let you pull up the shift plate. Have a look - they're known to break the plastic end connector on both ends of the cable.
Old Apr 21, 2006 | 05:43 PM
stevog66's Avatar
Engine: LG4 V8
Axle/Gears: stock
o.k. I will take a look at it.Thank You!!
84 Camaro F-41 Sport Coupe
V8 auto 700R4
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
timonator
Sep 30, 2015 12:52 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
