how to balance converter?
Old Apr 23, 2006 | 11:06 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
So I drove the T/A over 900 miles on a trip recently and noticed that there was significant vibration. Not at all speeds but especially noticable above 60MPH. Initially I thought it was the driveshaft I put in but when I took the car out of gear at speed the vibration went away as the engine revs droped. This made me think "aww S*&T", the motor is imbalanced or losing compression somwhere.
So I did a little reading on here and did my compression check, All 185-190 (whew! ). I also read that a couple members had a torque converter out of balance and unbolted it to test the engine alone.
Voila, the vibration went away with the converter unbolted. Motor reved great too (gotta get me a standard V8 one of these days).
So the question is -- is my diagnosis correct? Is the torque converter out of balance? It is a 2200 RPM "S10" converter I got from GM parts direct. Cheap I know but I thought it would work since Ive heard lots of guys getting one.
Next question would be, How the heck should I balance it. I really dont want to drop the trans so I wonder if I could put some weights or washers on the bolts to test it then weld on some weight when I get it right.
Thanks for any help.
Old Apr 23, 2006 | 12:00 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Sounds like an accurate diagnosis. They are balanced to the gram.
Old Apr 23, 2006 | 12:57 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
So I tried "clocking" the converter differently and it didnt really help. still a vibe at 2000. Is there an accepted way to add weight to the converter or flexplate?
Old Apr 23, 2006 | 02:48 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Ok, I clocked it again and it kind of helped in that now the vibration is less but all over the rpm range. This will have to do till I can spend more time on it.
Old Apr 23, 2006 | 04:19 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
If the converter is new, I would suspect it was not balanced properly. If it is a used converter and this vibration is new, I would suspect a failure internally, causing the vibration. The only way I know of to balance a converter is by a pro using the correct equiptment.
Old Apr 23, 2006 | 05:18 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Yeah, I may just spring for a better converter seeing as how I think this one sucks.
jamieriplilb
Exterior Parts for Sale
Oct 28, 2016 10:30 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
Magman
Sep 13, 2015 12:14 AM
89fast5oh
Sep 8, 2015 09:55 AM
