I think my linkage needs adjusted- not going all the way into park some times
Old Apr 27, 2006 | 07:44 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Ok- sometimes i shift my 700r4 into park- and it doesnt click in all the way- which way does my linkage need to go to tighten up the shift?
Thanks!!
Old Apr 28, 2006 | 08:32 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
If the problem isn't obvious on the tranny end, have a look under the shifter plate, its 2 bolts towards the rear of the shifter, and one under the ashtray. Remove the clip from the front of the t-handle shifter with needle nose.
Old Apr 28, 2006 | 08:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
On the 700R4, the lever on the tranny needs moved all the way forward for Park. There is no adjustment, other than about 3/4 inches of slot in the lever on the tranny side. A new cable is probably in order - they are about $30 or so - they can become frayed inside, and not push the cable all the way through, and there is no fix for it.
A note on cable install if you get a new one - make sure that, if you need to twist the cable any at all for installation (to get it fed through floor, or attached to tranny) - make sure you twist clockwise - this will keep the twist in the cable tightened (instead of loosening the twist) and keep it from yet again fraying on the inside. Install new cable from topside first, then attach to tranny.
Old Apr 29, 2006 | 08:47 AM
indirocz28's Avatar
Car: 1986 IROC Z-28
Thanks!, I might be looking for an aftermarket shifter anyways.. I have been looking at Hursts Promatic 2...
mustangman65_79
Apr 14, 2017 05:37 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Bryan F
Aug 18, 2015 02:28 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
