Help now. TH350
Old May 5, 2006 | 02:16 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Help now. TH350
I was all happy after getting the T5-Th350 swap done 3 weeks ago. It shifted perfect the 5 times I took it out. Never pushed it past 5000rpm. It sat for the past week. Took it out. Shifted into second gear and it barely moves. Has a 3500 Art Carr converter, so Im on the gas at 4000rpm and it just keeps the car moving. I dont think it is shifting into third either. First gear and Reverse work fine. Checked the fluid, it was at the bottom of the dipstick. Filled it up, same problems. Did a burnout just now with P275 M/T DR's. When its in second barely moving if I hit the gas real hard just for a second the car jumps like its about to take off, but then stops.
Are these obvious signs of a done tranny?
Old May 5, 2006 | 02:20 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Rebuild time! Actually check your vacume line going to your trans first that has some weigh on your shifting.
Old May 5, 2006 | 02:35 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Drop the pan on it,first be sure the filter is on properly,then check all of the bolts in the valvebody.I once had a TH350 in a truck do something similar,and when I pulled the pan to check it out,one of the bolts for the valvebody was laying in the pan.I put it back in,snugged up the rest of them,and that tranny worked perfectly for about 5 years after that.Just an idea,worth a shot.
Old May 5, 2006 | 04:34 PM
Shake Zula's Avatar
Vacuum line is fine. I dont want to drop the pan and replace the gasket and fluid. Might just call this car quits and start my other one. yes, I think I am giving up. This cars been nothing but a problem.
If the tranny were low on fluid wouldnt it take more than one shift to destroy second gear? And if second gear were weak, wouldnt it shows signs of it and not just go from good one day to dead the next?
Old May 5, 2006 | 05:48 PM
Shake Zula's Avatar
I knew this didnt make any sense. Now its workin again. I had to loosen the kickdown cable for some reason. But now its not tight enough cuz its shiftin late 3/4 throttle. I just have the cable looped over top the tranny and the end tied to the torque armk bracket.
Old May 6, 2006 | 07:00 AM
knj8's Avatar
Car: 89 Formula Firebird
Engine: 357
Transmission: turbo 350, EDGE 3500 stall
Axle/Gears: GMPP Dana 44, 3.73 gears
just a thought, but check the govenor. It's under the round cover by the tail shaft. It has a plastic gear on it that turbo 350's love to eat. If you lose it, you'll only have 1st and reverse no 2 or 3.
Old May 6, 2006 | 09:34 AM
Shagwell's Avatar
Car: projects.......
check the governor and hook the kick-down cable up properly.
Old May 6, 2006 | 06:36 PM
Irockz's Avatar
I agree on also checking the governor,I've also seen troubles with that.But,if he's oo lazy to pull the pan and filter,odds are that he won't be willing to check this either
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
