700 trans no revese
Old May 21, 2006 | 06:45 PM
jay92,85,79's Avatar
Car: 85z28,
700 trans no revese
Well it goes into revese but will not go back. its like one wheel is locking up or trying to go forward.. When i had the drive shaft out of the car u could push it. But with it in u can not push it back.. Any ideals?
Old May 21, 2006 | 11:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
what causes the 700R4 trans to not have reverse like that? with the motor off in neutral you can't push the car in reverse, and with it running it goes into reverse because you can see the car load up a bit, but takes a lot of throttle to get it to move backwards, and even then it does so with binding of some sort. any suggestions?
Old Oct 10, 2008 | 09:10 PM
64deux's Avatar
Car: GM WHAT ELSE IS THERE
Engine: 327 bottom tpi top
Transmission: 700r
Re: 700 trans no revese
I CAN NOT BELIEVE I AM HAVING THIS EXACT SAME PROBLEM IN 2008 THIS HAS NOT HAD A RESPONSE SINCE 2006 WOW HOW ABOUT SOME HELP
NOT SHOUTING JUST EXCITABLE
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
