How much to rebuild a t-5?
Old May 21, 2006 | 08:20 PM
pyro719juggalo's Avatar
Car: 1989 RS
Transmission: t5
Axle/Gears: 373 locker
I put a T-5 in my car its out of a v6 car but I got it in there and 1234 gear work fine. I have no reverse or 5th gear. So I pull the tranny out get it apart and everything is hooked up right. What is a good price for someone to rebuild this thing? I suck when it comes to trannys!!!
Old May 21, 2006 | 10:04 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
sounds like someone took the torx bolt out of the driver side.. just rip it back out and check it out. If you take that bolt out all hell breaks loose and you loose 5 and reverse. most people do it trying to drain it. .. a rebuild is about 150 if you do it yourself and thats including the manual to show you step by step how to do it.
Old May 21, 2006 | 10:20 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Old May 22, 2006 | 08:19 AM
Car: 1989 RS
Transmission: t5
I got it all apart The torx screw was still intact the clip was still on there I didnt take it all the way out. Everything looks clean in there I dont understand why I didnt have 5th and reverse? Does that torx screw need to be tight for those gears to function?
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
