do i need a torque converter?
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
i have an 85 T/A with an 89 vette engine in it and tranny(with a shift kit) the engine has rockers,cam,headers,aluminum heads, 4thgen rear end 3.42 gears, i drive it daily, and don't take it to the track much but i will soon, i do street race though with a bunch of others, a torque converter never came across my mind and do i need one or not what you guys think thanks.
Car: '82 Z28
Depends if you have an automatic transmission or not. Since you do have an automatic trans, you already have a torque converter. Now if you're asking if you need a higher stall converter to match what you've done to the engine, specs of the parts would be handy.
Car: 85 T/A
i ment do i need to upgrade my stock one i know i have one lol sorry i wasn't clear my bad, its a stock one off of a 89 vette and i do a little racing on the street but i know they have downsides if your car is an everday driver and you upgrade the converter.
Car: 85 T/A
Originally Posted by EvilCartman
Still need to know what the cam and heads actually are.
the cam is a zz4 cam and the heads are the stock aluminum heads that come on a 89 corvette, there D port heads(don't know if that helps). the stock torque converter on the vette i was told has about a 2100 stall which i think is good enough for daily driving and then racing at the same time. my stock one came with like 1400 i think not sure though.
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
b&m 3200 stall... acts like a normal lower stall till u make it go up to 3000ish rpm... there great tooo... at 30 u can flash down to 1st gear and roast the tires....
Ragtop Man
Sep 12, 2015 12:23 AM
