7-5/8 10 bolt posi
Old May 31, 2006 | 09:07 PM
BAD3rdGEN's Avatar
Car: 1986 Z28
Engine: 10:1 355 4bbl
Transmission: th350 modified
Axle/Gears: 3.42:1 posi disk brake 10 bolt
7-5/8 10 bolt posi
i shelled out my 3.42s and was woundering if i should disasemble and clean it out or just clean it up.i have never worked on one before. i need advice.
Old Jun 1, 2006 | 03:24 AM
ede's Avatar
ede
what's the differance between "clean it out" and "clean it up"? while you're defining things what's "shelled out" mean.
Old Jun 1, 2006 | 05:05 PM
BAD3rdGEN's Avatar
Car: 1986 Z28
SHELLED OUT MEANS THE PINION GAVE OUT AND SHREDDED THE RING GEAR.THERES ALOT OF METAL SHAVINGS IN THE CARIER, SHOULD I TAKE THE POSI APART TO CLEAN IT OUT?
Old Jun 1, 2006 | 05:28 PM
ede's Avatar
ede
press the cap lock key when you type, no one likes reading in all caps. i tihnk i might want to get some or all of the chips out before i ran it again. don't think i'd want to disassemble the carrier, you ought to be able to clean everything without doing that.
Old Jun 1, 2006 | 05:53 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
should definately pull the carrier apart. any little shavings in there will mess it up in a hurry!
BTW, please turn off the caps
Old Jun 1, 2006 | 06:55 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
while you're down there, nows a good time to throw on a solid pinion spacer, weld the axle tubes, and get a think aluminum differential cover...
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
djmarch
Sep 13, 2015 01:35 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
